Does Lightburn work with the Fox Alien Masuter CNC Router?
Does Lightburn work with the Fox Alien Masuter CNC Router? I just bought it and got it hooked up and would like to use Lightburn since that is what I use with my Diode laser. I would much rather use Lightburn then the included “Candle” program that came with it.
Just to be clear. If you’re using it as a laser, I think it will work OK.
One of the on-line sellers include Lightburn with some of their packages. I assume they all use grbl.
Candle is grbl based, so if Candle is your gcode sender then it should work.
It sounds like you already have Lightburn… plug it in, create a new devices… and enjoy…
I did try that… But when I plugged it in and did the “create new” it couldn’t find the device
Try creating the device manually. Auto-detect doesn’t always work.
