Im trying to design a project.
Its a design of an object and there are some open areas when I vectorized it.
So i drew a freehand outline around the whole object in a drawing program.
But when i import it back into Lightburn the outline I drew appears as double line (the inside and outside of the line?
I then put an offset around the whole piece and use that as the cut line, the rest is just engraved.
I can not use the offset feature without the outline because of the open parts of the design.
hope that makes sense?
