Double Line On X Axis
I’m getting a double line when I’m engraving a bidirectional fill along the X axis. My first thought was the belt or it’s gear was loose. Sadly it wasn’t.
The shadow image is about 0.3mm off
The problem doesn’t happen when turning off the bidirectional fill or along the Y axis.
Laser head is tight.
Any thoughts on what I should inspect?
The image below should be a single line and is one of the two lines in the LB file.
Here’s the file
maple leaf-4.lbrn2 (212.8 KB)
Measuring and filling out the Scanning Offset Adjustment values should fix that:
Run the test pattern at 50 mm/s, then every 100 mm/s up through whatever the machine’s maximum speed might be.
A measuring magnifier will be helpful to get meaningful results.
Ed’s guidance is what I would recommend here - when you move the laser head really fast, even with a tight motion system, there’s some induced flex/stretch in the belts that needs to be accounted for.
Interesting, I’ll give that a try. Thanks
Truth be told, I wasn’t having this problem over the weekend.
@Colin
@ednisley
The one on top was from earlier today
The bottom on was from a couple of days ago.
Tightening the belt did help a little compared to the image in the first post
Then, no matter how sure you are, it’s a mechanical problem.
Check everything for the loose widget you missed the last time around. You’re trying to find a motion of less than a quarter of a millimeter, so being patient and thorough beats knowing this thing can’t be the problem.
Source: been there, knew that. :grin:
This may help. You have Xaxis backlash.
@ednisley
@Colin
I’m sure of that too.
I even played with the Offset Adjustment JIC, which didn’t help.
I Double Checked everything and when I finish typing this I’ll start my third time.
Is it possible I need a new belt or maybe the stepper motor is causing the slack?
Each line in 0.5mm
Perhaps going down through a list of things to check will help. This is for Sculpfun machines, but they’re all similar enough to have the same gotchas:
Reports from folks showing how hard it can be to find The Loose ThIng after you know you’ve checked everything:
Unless it’s loose on the frame or the pulley is loose on the shaft, a stepper motor won’t be the problem.
Thanks Ed, I’m back in business.
The only thing I didn’t do was to check the eccentric nut
@ednisley How do I mark your post as the solution?
Alas, Community Laser Talk lacks that checkbox, for reasons I cannot explain.
It’ll go on my list of “So you think you’ve checked everything …” notes. :grin:
