Draw a box around an object
I have two objects in my job. When I select the is there a way to have LightBurn draw a toolpath around them? The toolpath should be a square or rectangle the size of the two objects.
Thanks,
Doug
You could use the offset tool and change it to a tool layer
Thanks! An interesting idea, actually, and one I had not thought of. Does not work in this case as this is a logo and not rectangular.
You could also select the shape and note the H and W. Draw a square and select it. Put it on the tool layer then click the unlock and input the H and W noted before. Use the center tools to put the box over the shape.
