I have a boss laser C02 laser. I am trying to draw lines on 3mm basswood. I have it at the lowest power and the fastest speed so I am not cutting just making lines. However at the start points and end points it penetrates the wood with holes at the start and end points. Is there any adjustment for fixing that? Thank You
Welcome, and thank you for your question. What is the wattage of this Boss Laser? What settings are you using currently? Please include the units for speeds. ![]()
We suggest using perforation mode with small cut/skip lengths for this when using high power and can’t get low enough with just Min Power adjust. ![]()
What’s your min power set at?
Min power needs to be set at just below your machine’s lasing threshold.
All too often people don’t understand what it’s there for, and set it to the same as max power.
The min power is used to proportionately scale back power when it’s below the commanded speed during vector cuts and engraving. This will happen on vector start/stops/corners or really tight curves. It doesn’t apply to rasters except grayscale mode, where it has a different meaning.
If you ask for 300mm/sec, it’s still got to start and stop at 0mm/s and accelerate through every speed in between. So at the point it’s 50mm/s, you need 1/6th the power to get the same burn.
It will scale as 1/6th the way from min power to max power duties. If your machine stops lasing at 17% duty, this generally be the best choice for min power- the HVDC excited machines are very nonlinear so it’s not a perfect solution.
If you ask for 300mm/sec 100% max power 17% min power, then when it’s at 50mm/sec it will be (max power-min power)*(current speed/commanded speed)+min power=30.8% duty.
If you left it the same % as max power, it will not be able to scale power back at all and overburn the starts/stops/corners
It’s not a perfect process. When you ask for higher speeds, the acceleration zones get larger and the scaling is a bit more problematic. And if you’re engraving text and ask for 300mm/sec, it may never get above 50mm/sec and always deeply in power scaling. I find I can get somewhat more consistent results with, say, 30-50mm/sec on smaller text and pulling the max power way down proportionately.
Thanks @Dannym for this. I could have been clearer; sharing these details helps with understanding.
And, with a Ruida controller, Dot Mode can work wonders.
I think I somewhat follow you, but you lost me at 30.8% duty [cycle]?
How this is scaled is based on the value of the start speed, set in the controller and both min/max power.
The amount of power can be scaled depending on the setting of the start speed, minimum and maximum power. There’s probably some type of mathematical formula or relationship, but I don’t think it’s so simple as @Dannym advised, since he doesn’t seem to take into consideration the start speed in his computations.
As far as I was able to measure things, it appears to work this way. So you really have lots of control.
If your head is equal to or below the start speed, all you will get is minimum power.
I never set anything I need below it’s lasing point.. Why would you want it to completely turn off, but I’ll try it to see what happens when I cut something the next time.
I though I’d tried this before and the points didn’t lase through, but actually don’t recall.
If you want to run fast, you need an RF machine as it’s about 1000 times quicker, however most of us can’t afford one. The other option is to figure out how to make it accelerate faster. There isn’t really much except acceleration value.
This is an example of the difference in job time using a higher acceleration value. Both are the same job, just the acceleration value has changed. Stock machines are in the 5 to 8000mm/s^2 range. This graphic shows, on the left a 40000mm/s^2 value compared to a 6000mm/s^2 value.
I used preview and enabled ‘show transversal moves’ shows you where the head travels and not lasing in red. Note the time difference for the same job at the same speed.
Good luck, this should really confuse us… ![]()
Right, I should have said to set min power just above the lasing point.
Good point about the start speed, but it’s never factored in in my usage. Wanted to keep it simple.
The point about 300 mm/s vectoring text isn’t about RF machines. I tell people the basic starting point for cutting is 100% power then adjust speed to the fastest that still cuts through.
For engraving, that still holds up somewhat if you have a low power machine and want a deep mark in acrylic. The speeds that get the mark you want may not be crazy high.
You can “sort of” continue to use that principle to regulate the cut depth by giving 100% power and crazy high speeds it may never reach. This will scale back the power at all speeds, and seems like it should work, and it does, but not that well, as it’s always doing really high and widely varying scaling ratios, making inconsistent results. Thus the second lesson which says maybe it’s better to cut back the max power and max speed, but always keep min power at the standard calibrated number for the machine.
RF-CO2 can scale much better in general, since it has no true minimum power lasing threshold and basically a linear response. RF-CO2 is actually the case where you can get still get good results by giving a high speed and 100% power to limit the depth of vector engraving, up to a point. But still a good idea to consider limiting both power and speed together.
