Drawing polygon
How do you Edit the number of sides your polygon tool will make?
Draw the default hexagon using the shift or control keys as desired. Open the shape properties panel to set the number of facets.
Where is shape properties at? Can you show a screenshot?
I found it after much digging. It is under “window” then check that, then go to the tab next to cuts and layers. Kind of an odd place for it. It should have been under the edit tab.
Select object. Right mouse click. Show Properties.
