Drawing Tools - feature request
I’m a happy LightBurn user who came over from Vectric. When I first bought my laser machine, I used V-Carve Pro to create DXF files, then exported them to LightBurn for cutting. I used this workflow because Vectric has better drawing tools. Now that Lightburn has largely caught up, I’ve dumped V-Carve and now do my original drawings with Lightburn. Below are a few things that I wish Lightburn had:
  1. An Extend Vector drawing tool. Extend Vector takes the current vector and extends it outward until it touches something.
  2. A Cut tool (scissors) that works when you drag it across vectors.
  3. Docking - I absolutely love docking. PLEASE make it work INSIDE shapes. To dock a shape to the inside edge of a circle, you must first draw a line outside the circle, then dock it to the circle. Then, dock the object inside the circle to the line, forming a tangent to the circle. In general, Docking needs to work INSIDE, and it should touch lines, not just bounding boxes.
  4. When using the basic shapes (rect, ellipse, polygon, etc.), returning to Select mode is accomplished by either clicking the icon or by hitting ESCAPE. While drawing, there is no right-click context menu. A right-click should therefore exit draw mode and return to Select mode. This just makes it handy.
  5. I use the Measure tool a lot. It cannot be canceled with ESCAPE. Why not?
  6. Virtual arrays are a nice touch. It would be nice if they were available with circular arrays.
I’m generally very impressed with this product’s trajectory. I would definitely recommend.
Hi @flloyd
It’s great to hear you’ve moved your drawing workflow over to LightBurn, and thank you for the positive feedback and for taking the time to put together these suggestions.
Our feature request site is the best place to log these, allowing other users to vote on them and helping us gauge interest.
The scissors-style cutting tool has already been suggested here, so you can add your vote and comments:
I’d encourage you to submit the other suggestions individually, after checking for existing requests, so each can be considered on its own merits rather than assuming a Developer might wander in and see them for action (but you never know).
fred_dot_u and fred lloyd are pretty close, I suppose. (grin)
Ooops! Sorry about that.
Thanks! The scissors tool suggestion is now eight years old.
There is a scissors tool - Trim Shapes - LightBurn User Guide
And there’s still work being done to further improve that tool internally - but your recommendation of a drag to cut type workflow is novel, if it isn’t already on fider, we’d love to see it there!
