DSP Controllers compared to System on a Chip boards
So one could not expect to hack the binary data format as one would with the G-Code. Not something I had thought about. That helps a lot in understanding what you can and can’t do. FPGA’s also take some time to boot but since i don’t have a Ruida yet, not sure about that and not probably a issue anyway.
Should one expect to be able to do finer work with a Ruida controller than a GCode one? As a matter of timing and speed. Would you need to slow a cut to get the same level of detail between the two?
Thanks for your answer.
