Dual Head Problem (Laser 2 disappeared)
Hello.
I have a Co2 laser machine with 2 heads, my main head is Laser 2.
In previous versions of LightBurn there was an option to choose what head I want to use.
In the recent version I can’t find this option anywhere, that makes my laser useless with LightBurn because I can’t activate Laser 2.
Can you please help me find where in the software I can activate Laser 2?
first the layout changed a bit but it will also only show when you have your laser on when you start lightburn (very annoying)!
When enabled the two heads show in the cut settings editor.
dualheadcutsettings
you have to activate the 2 heads in machine settings, laser (and press write)
Enno, Thank you for pointing me in the right direction.
Everything was already configured correctly in my laser.
What I needed was for LightBurn to READ the laser setting and than the Laser 2 option appeared. :slight_smile:
glad you found it
