DXF Files Not coming right
Hello,
The new light burn update 1.1.03 Dxf files are not coming in correct ?? Is there a way to go back a update ?
Light Burn is currently looking into it DXF files are not correctly importing in Inches but are ok in millimeters.
I noticed this also after updating software. It scrambled the text into odd shapes. You can uninstall lightburn and re-install an older version. If it doesn’t work correctly then, uninstall again, and then search for the word “lightburn” on your system, and delete those files also. Then re-install. I used version v1.0.06, and just use mm until they get it fixed for inches. Go to download page for older versions.
Roy
