The question, when importing DXF file with text. The customer has a Text on his part at 45 degrees to fit inside the part. When I open (import) in LB the text is straight and outside the part. When open in Cad or RD works, the text is correct at 45 degrees. Any ideas?
Not all features of text are supported yet, but rotation should be easy enough. If you can send the file to developer at lightburnsoftware dot com, I’ll add support for it. In the meantime, if you can use the source application to convert the text to curves and re-export, that will fix it.
