Bonjour,
Quand je veut graver en Echelle de gris le laser avance tout doucement en saccadant , mais fonction trés bien dans les autres modes d image . Si quelqu un pouvais m aider . Je sais pas si j ai fait une mauvaise manipulation ou autre mais avant cela marcher très bien
Merci par avance
Hello,
When I want to burn in Grayscale the laser moves very slowly, jerky, but works very well in other image modes. If anyone could help me. I don’t know if I made a bad manipulation or other but before that it worked very well
thanks in advance
How fast are you trying to engrave? If you have an 8-bit GRBL controller, it will not process GCode instructions very fast - probably about 200 instructions per second.
J imprime a 1200 , j ai deja gravé plein de fois sans soucis et la d un coup le mode echelle de gris grave tout doucement en saccadant , les déplacements se font a la vitesse normal , juste le problème quand le laser grave
I print at 1200, I have already engraved a lot of times without worries and suddenly the grayscale mode engraves very slowly with jerking, the movements are done at normal speed, just the problem when the laser engraves
In the LightBurn Console, type $$ then Enter / Return. This will spit back the current grbl settings you have set in your controller. This is one location you can use to review the current setting for $32.
