I’m trying to edit the nodes on the stem of this cake topper to have a rounded or pointed bottom but when I click the edit nodes tool or try to insert nodes nothing happens?
Also… once welded like I have in these pics, is there any way to determine the width of the stem or do I have to check that before welding?
And lastly… when I have my screen zoomed in on my project, is there any way to move the screen left right up down etc to focus on different parts of my project?
The only way to undo the weld would be the actual undo function in Lightburn. You can finagle some node editing, breaking nodes apart, putting them back together, etc, but it might just be easier to start over. Especially with something simple enough like text.
You can also just draw small circles or rectangles over the bits that need connecting and then weld them in too. If the spots are small, this works well enough.
