Can’t get the eleks maker 6550 to actually “burn”. The machine is connecting with the lightburn software. It will move and the laser come on…but won’t actually “burn”. What am I missing? Thanks for your help.
Quite a bit of info. Can you post what you tried to burn, the settings you used, and which device driver you chose in LightBurn, as a start? Depending on the driver used, if you tell it to go too fast, the controller may scale the power down if it can’t meet the speed you asked for.
There are also settings that affect the power numbers used between LightBurn and the controller, and if they don’t agree on the number for “full power” that will cause problems too.
