Elongated UI pop-up windows cutting off action buttons on Windows 11 Touchscreen PC
I am writing to report a user interface bug in LightBurn Version 2.1 affecting high-DPI and touchscreen devices on Windows 11.
When opening secondary sub-windows—specifically the Material Test Generator (Edit Material Setting) and the Device Camera List / Camera Wizard layouts—the pop-up boxes display artificially elongated and scaled too large. As a result, the action buttons at the bottom of the window (OK, Save, and Finish) are pushed past the physical screen boundaries and hidden behind the Windows taskbar.
Because these buttons are inaccessible, I am unable to save newly added camera profiles or preserve modified test settings. Standard workarounds, such as pressing “Enter”, do not reliably trigger confirmation across these windows.
Could you let me know if there is an upcoming hotfix for this UI issue, or if a beta patch or command-line argument is available to temporarily resolve the scaling?
System Specifications:
  • LightBurn Version: 2.1.04
  • Operating System: Windows 11 (Touchscreen laptop)
  • Connected Hardware: OMTech Polar 2 Pro 50W RF Laser (Ruida controller)
Hi Leonard,
If you go to Edit in the top menu bar > Settings, then click the Display tab, you can adjust the scaling factors to fit your screen.
Try adjusting the highlighted settings above, and if no joy, please reply with a screenshot of your settings page, and ideally the material test generator window showing the issue.
The first screenshot shows the settings changes I made per your example. The next screen shot shows the still elongated popup window for the materials test generator.
Please advise.
The window shouldn’t be that long - @Brodie have you seen this before?
Can I ask what your PC’s screen resolution is?
Mine looks like that too.
Win10, 1920x1080, 100% scaling.
175% scaling Win11 1920x1080.
175% from 100% made no difference in mine, Win10.
I’m not seeing this with the LightBurn 2.2 RC in the Material Test generator - could you give that a try and confirm it works for you?
Our dev team suspects this is a bug, and will be taking a closer look this week.
In v2.1.04, Cuts Editor for images is okay. For vectors it is not.
In v2.2.00-RC1 it is okay for both.
Win10
This has now been fixed, and appears to already be available in the LightBurn 2.2 RC here: LightBurn 2.2.00 Early Access — RC-2
