Is it possible to have the switch for enable rotary and the x0y0 locations settings remembered in the saved part.
This is so if you go back into a cut or engrave part you don’t wreck the part because you forgot to turn rotary switch or change home position.
I have an extra stepper drive for the rotary and a switch at the connector to the rotary jack which enables the rotary stepper of the y axis stepper. That doesn’t seem to be a problem to remember that step but often I forget to turn off rotary switch and home location.
This is only for saved parts whether rotary or xy mode it would save those two settings in the saved parts.
