Hi guys, i am trying to Enable laser fire button, but the option is not at my Device settings,
I am using sulpfun S9 laser,
thanks
thanks
That feature is not supported by CanCam devices.
I guess the real question is why have you configured your Sculpfun S9 as a CanCam device? This should be a GRBL device.
Suggest you delete the current device and create a new device of type GRBL.
Ah - yes, I missed that last comment after seeing the screenshot.
You don’t need to delete and recreate even - just go to the devices list, select that device, click edit, and then select the Grbl device type instead of CanCam and continue through the device config process.
Thanks for the reply both of you guys. Problem solved, Skulpfun did not recognized automatically from software and i had wrong manually settings as newbie. Grbl was the key…
Now works fine.
