Engrave Area Limit
I seem to remember that only items within the Work Table could be Cut/Engraved or Previewed.
Now V1.7 that control is not there ? Can we get it back? or is there some switch I need to set.
Thanks Problem solved by turning on Cut Selected Graphics on the Laser panel…
Don’t have this button?
This?
Thanks for the help this will work for me.
Richard…
Thanks for your reply. I’m not to sure what this does it didn’ solve my problem of engraving non selected objects outside the work area. suggesstion from another member to turn on Cut selected shapes on the Laser panel has solved the problem for me.
Thanks again for your help.
Richard…
If you work in Absolute Coordinates and have this (ignore out of bounds) turned on it will pop a warning about anything outside the work area and it will not burn those items.
If you work in User Origin or Current Position that does not apply. The correct option is Cut selected graphics as you said.
