Engraved but didn't cut
[DATE:20230223]
[SN:2B7F7E2CEEA0CCA818F6FF7667249A85
[VER:1.1f.20220325:]
[OPT:VNZHTS+W,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:84:F7:03:E6:88:76]
[IP:10.0.0.26]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
[MSG:25:Info: USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:210.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:210]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230223]
[SN:2B7F7E2CEEA0CCA818F6FF7667249A85]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
Port failed to open - already in use?
OLF:210.
OLM:GENERAL.
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:210]
[OLM:GENERAL]
[DATE:20230223]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767>
ok
Starting stream
Stream completed in 0:00
<Home|MPos:0.000,0.000,0.000|Bf:63,32767>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|VA:24553,101|A:SFM>
<Home|MPos:-39.960,-39.960,0.000|Bf:63,32767>
<Home|MPos:-79.970,-79.970,0.000|Bf:63,32767>
<Home|MPos:-119.980,-119.980,0.000|Bf:63,32767>
<Home|MPos:-159.990,-159.990,0.000|Bf:63,32767>
<Home|MPos:-200.010,-200.010,0.000|Bf:63,32767>
<Home|MPos:-240.020,-240.020,0.000|Bf:63,32767>
<Home|MPos:-280.020,-280.020,0.000|Bf:63,32767>
ok
$0=5.0
$1=100
$2=0
$3=1
$4=7
$5=0
$7=0
$10=3
$11=0.050
$12=0.002
$13=0
$14=0
$15=3
$16=1
$17=4
$18=0
$20=1
$21=0
$22=1
$23=7
$24=600.0
$25=800.0
$26=100
$27=1.000
$28=0.100
$29=0.0
$30=1000.000
$31=0.000
$32=1
$33=2000.0
$34=0.0
$35=0.0
$36=100.0
$37=0
$39=1
$40=0
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.0
$57=1800.0
$58=395.0
$59=6000.0
$60=0
$61=1
$62=0
$63=3
$64=0
$70=31
$73=3
$74=BigMar
$75=**********
$76=OLM3_AP_8876
$77=12345678
$100=100.000
$101=100.000
$102=100.000
$110=20040.000
$111=20040.000
$112=600.000
$120=2000.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$140=600
$141=1000
$142=800
$150=16
$151=16
$152=16
$160=0.000
$161=0.000
$162=0.000
$180=20040.000
$181=14028.000
$182=600.000
$200=65.0
$201=50.0
$202=60.0
$210=100
$211=100
$212=100
$220=50.0
$221=60.0
$222=60.0
$270=115200
$271=115200
$272=115200
$300=OLM3_STA_8876
$301=1
$302=192.168.5.1
$303=192.168.5.1
$304=255.255.255.0
$305=23
$306=80
$307=81
$308=21
$310=OLM3_AP_8876
$312=192.168.5.1
$313=192.168.5.1
$314=255.255.255.0
$330=admin
$331=user
$332=255
$339=3
$341=0
$342=30.0
$343=30.0
$344=180.0
$345=200.0
$384=0
$392=5.0
$393=3.0
$600=0
$601=5
$602=0
$603=5.0
$604=6.0
$605=1
$606=1
$607=0
$608=1
$609=10.000
$610=0
$611=0
$612=1
$613=1541
$614=0
$615=api.ortur.cn
$616=0
$617=0
$622=127
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|VA:24567,70|H:1,7>
ok
Starting stream
Job halted
OLF:210.
OLM:GENERAL.
Rotary setting update successful
Waiting for connection…
ok
OLF:210.
OLM:GENERAL.
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:210]
[OLM:GENERAL]
[DATE:20230223]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
ok
Starting stream
ok
Starting stream
ok
Starting stream
ok
Starting stream
ok
Starting stream
ok
ok
ok
Starting stream
<Idle|MPos:0.000,10.000,0.000|Bf:63,32767|VA:24511,374|A:SFM>
ok
Starting stream
<Idle|MPos:0.000,20.000,0.000|Bf:63,32767|VA:24564,70|A:SFM>
ok
Starting stream
<Idle|MPos:0.000,30.000,0.000|Bf:63,32767|VA:24633,73|A:SFM>
ok
Starting stream
<Idle|MPos:0.000,40.000,0.000|Bf:63,32767|VA:24525,207|A:SFM>
ok
Starting stream
<Home|MPos:0.000,50.000,0.000|Bf:63,32767|VA:24564,72|A:SFM>
<Home|MPos:-39.950,-39.950,0.000|Bf:63,32767>
<Idle|MPos:200.000,200.000,0.000|Bf:63,32767|VA:24581,76|A:SFM>
ok
Starting stream
Starting stream
Layer C02
Layer C00
Stream completed in 1:20
Starting stream
Layer C02
Layer C00
Starting stream
Layer C02
Layer C00
Stream completed in 0:36
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
OLF:210.
OLM:GENERAL.
[MSG:‘$H’|‘$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
To get a good cut:
  1. Make sure your focus is quite good
  2. Set the layer mode to “Line”
  3. Adjust settings until a cut is achieved
    3a. increase power
    3b. decrease speed
    3c. increase number of passses
  4. Repeat 3 until you get the cut that you want
How do you focus the laser?
Thanks
I believe on your laser you need to position the laser module’s kick stand down and have the kick stand touch the top of the material to be burned.
