Engraved lines not perfectly straight - wiggly or squiggly..using a Scuplfun S9 GRBL
I downloaded a grid pattern to use on a waste board to aid in squaring up my projects. It was an SVG file. I tried to burn the image on to the waste board but the square box lines are not perfectly straight they are wiggly. I would appreciate any advice or direction to help me solve this problem!
I had this same problem which was easily fixed. You might need to tighten your belts, I did and the wiggles went away.
Thank you!!!
