Hi. I have created an AI design for my folding knive handle. It looks perfect but it is png file. I tried converting to vector with some tools but all results are ugly. Is there any way to engrave this?
I have 60w JPT mopa fiber laser machite.
You can engrave an image just the same as a vector graphic. So just import it and start. ![]()
You can set different algorithms etc., this depends on your requirements. It will need some testing.
You can also Adjust image in Lightburn >=1024 DPI, grayscale mode, adjust contrast a bit, after do a trace and a Preview.
I dropped it into Gimp and removed the background. Then in Lightburn for the rest.
I did a trace, it seemed work with no problem.
I didn’t do the whole image here…
Try this version.
knife-graphic.lbrn2 (366.2 KB)
If set to fill, you have this…
Does this help at all?
I don’t know what this does for you, maybe you can explain how this helps? Unless the original is greater than you have, then it could be a benefit, other wise when you scale it up, the computer guesstimates how to set up the extra bits. Meaning there is not higher resolution, just letting the software add data that doesn’t exist.
If you can explain how this works, I’d greatly appreciate it.
