Engraving is off centered, but cutting is not
I just did the latest update. Now, when I cut and ornament circle with “2024” to be engraved in the middle, the cut is exactly where it shows on the screen, but the engrave is about an inch off to the right, and a little bit lower than what it shows on my screen. I’m confused why it’s suddenly doing this, but even more confused why the circle is cutting and scoring exactly where it should if the engrave is not?
My machine is an xtool d1 10w. Thank you.
Review your Offset Scanning Adjustments in Edit->Device Settings. Do the values look reasonable? Try disabling to see if that gets you closer. If so, you’ll likely need to recalibrate.
