Hey everyone…just got the new and fancy setup built from LO. This is an existing AWC608 computer on a new PR650 stage with a fresh SPT 45W tube.
But I’m having a few issues I didn’t have on previous laser builds. I suspect something is wonky with my X-Axis since the engraving is really out of whack, but also when I cut anything with a circle it’s also a bit weird and misshapen.
Things I’ve done:
Upped/changed current to the motors.
Ruled out the step setting (uM) is the issue since I can drastically move it around and the issue stays.
Calibrated to within much less than a mm.
Loosened belts to make sure they weren’t too tight.
Alignment is pretty centered within the 5mm nozzle hole.
It seems to cut anything square, exactly to size.
If I cut rounds, then it won’t finish where it starts.
Engraving-
X-Swing Unidirectional, it’s a flawless engrave
X-Swing Bidirectional, it’s horrible (regardless of speed)
Y-Swing Bidirectional, it’s not quite flawless but quite nice
Y-Swing Unidirectional, untested.
I’ve attached photos of the settings of my machine, of the X & Y axis and the image of the engraving/cutting issues.
Ok so a bit of an update. While I did find something wrong with my belt (it had twisted inside the tube), that wasn’t the issue.
I spread out the scan gap to see what was happening and it’s not that I’m missing steps as much as it being off-set.
What would cause a consistent off-set step? This can’t be mechanical, it’s every “back swing”. Can you have a bad connection to one half of the coils in your stepper? It cuts squares perfect.
Thanks for the thought. The top one is non-bidirectional which makes sense.
I’ve had the same thought, that it might be the sync but the speed is so slow, I don’t know that it’s the same issue since I can’t cut anything circular properly (see the picture higher up with the weird oval).
There might be something to the rising edge/falling edge thing. I’m going to investigate further on that front. If I have time, I’ll hook up the 'scope to it and see what it shows.
