Hello,
I experienced a crash right in the middle of 90 minute engraving run. I tried to upload a zip file with the tail end of the console file and the Code for the job, but this system will only allow me to up load the Gym.lbrn2 the Lightburn file for the job. Here is the tail end of the console file documenting the crash.
MPos:223.100000,91.650000,0.000000,0.000000
Starting stream
Stream completed in 0:00
[MSG:Pgm End]
Project file saved as No Secret Handshakes.
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
Layer C01
Layer C05
Layer 03
Stream completed in 49:10
[MSG:Pgm End]
ok
Starting stream
Layer C01
Layer C05
Job halted
Stream completed in 2:09
Project loaded in 208 milliseconds
ok
MPos:242.860000,72.870000,0.000000,0.000000
Starting stream
[MSG:Pgm End]
ok
MPos:244.010000,70.310000,0.000000,0.000000
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
Layer 03
Layer C01
abort() was called at PC 0x4008c767 on core 1
ELF file SHA256: 0000000000000000
Backtrace: 0x4008e5b4:0x3ffb3a00 0x4008e831:0x3ffb3a20 0x4008c767:0x3ffb3a40 0x4008c78d:0x3ffb3a60 0x4008c8e1:0x3ffb3a90 0x40107726:0x3ffb3ab0 0x4010a995:0x3ffb3dc0 0x400868c1:0x3ffb3df0 0x400e5f6d:0x3ffb3e20 0x4014da79:0x3ffb3e70 0x4014e995:0x3ffb3e90 0x400d16be:0x3ffb3ed0 0x400d1846:0x3ffb3ef0 0x400d1c59:0x3ffb3f10 0x400d302d:0x3ffb3f30 0x400d3039:0x3ffb3f50 0x40081b5c:0x3ffb3f70 0x400d2b56:0x3ffb3f90 0x400e4671:0x3ffb3fb0 0x4009049e:0x3ffb3fd0
Rebooting…
f~f~
M2001 192.168.1.200
Is this a problem in the XTOOL D1 or is it a Lightburn software issue. I was running this job from my MacBook Pro M1 that is running the latest version of the macOS Monterey operating system. The XTOOL D1 was connected to the MacBook via a USB connection. I have run other similar jobs without issues. I would appreciate any advice.
Thank You,
Philip Ershler
ershler@icloud.com
Gym.lbrn2 (1.8 MB)
