Hello
a few days ago I made an engraving program with the Z activated at -5 mm but with each shape it goes back up then then lowers the Z how to prevent it from doing its shapes have the same color
thank you
ok merci je vais essayer mais mon essai 30 jours arrive a son terme et j’attend encore avant achat
If you need, @oz can extend your trial another 30 days I believe. Then you can test it fully.
(Google Translate)
Si vous en avez besoin, @LightBurn peut prolonger votre essai de 30 jours supplémentaires, je crois. Ensuite, vous pouvez le tester complètement.
