Entire image not traced
I am having trouble tracing an vector file.
![image|690x437] (upload://2vsHr3Tq54RhgF2nxMlDQrB6J91.png)
This is all I can get it to pick up-
What am I doing wrong?
This this
Did you try changing the threshold number?
When I use the art provided above, I have found these settings to help.
I find that fading the image while I zoom in and out around the image allows me to see the results as I adjust the threshold setting.
Here is the result, unedited, set to Fill shown in the ‘Preview’ window.
And this one shows that I have set the “slice” and the “e” shapes to a different layer with different cut settings (wider scan gap and lower power), resulting in a lighter cut as you show.
Is this what you are after?
Or with a little adjustment to the gamma and brightness of the original art, you could engrave using the raster image itself.
Thought you wanted to do a trace image
or you trying to run it as a image?
Load the image in light burn do a trace image. Then use fill
OP was for Trace. I believe the OP did “Load the image in light burn do a trace image.” but they were not getting the results they wanted. That is why I suggested the adjustments provided above.
In addition to providing answers to that request, I was also offering a different way to get similar results using a different workflow.
Thank you! Your suggestion of fading the image and lowering the threshold worked! Much appreciated!
