Ale
(Alessandro Guerin Testolin)
September 15, 2025, 11:31pm
1
boa noite estou com esse erro na cnc lazer e ele nao sincroniza alguem pode ajudar
V4.00(8M.H35.20231120)]
[VER:1.1h.2023112002:]
[OPT:VMPH,63,256]
Target buffer size found
[MSG:Using machine:MKS DLC32]
ok
[MSG:Mode=STA:SSID=:Status=Not connected:IP=0.0.0.0:MAC=48-27-E2-80-4B-18]
[MSG:Mode=AP:SSDI=Laser_6219:IP=192.168.4.1:MAC=4A-27-E2-80-4B-18]
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Grbl 1.1h [‘$’ for help]
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
MikeyH
(Mike Hembrey)
September 16, 2025, 1:56am
2
Good evening, I have this error on the CNC laser and it does not synchronize. Can someone help?
Your PC and laser are obviously communicating. What do you mean by “does not synchronize”?
Ale
September 16, 2025, 2:09am
3
Aparentemente estão se comunicando sim, porém na hora que vai ligar ele aparece esse erro e não conecta com o notebook, aí preciso ficar desligando e ligando a CNC para tentar conectar
MikeyH
(Mike Hembrey)
September 16, 2025, 2:12am
4
There is no error listed, except it not connected using an IP address.
Does your TwoTrees laser try to Home when you connect to Lightburn?
If not, will it try to home using the Home button in the Laser window?
Ale
September 16, 2025, 2:27am
5
A mensagem que aparece e essa que coloquei a cima, antes quando eu usava outro notebook acontecia isso achei que era devido ao notebook ser mais velhos peguei outro notebook mais novo e persistiu o erro, com isso troquei o cabo que liga a CNC com notebook não resolveu, atualizei o firmware e tbm não resolveu
system
(system)
Closed
October 16, 2025, 2:27am
6
