Just connected the laser to lightburn and trying to do an engraving but get this error
error:20
Unsupported or invalid g-code command found in block.
error:20
Just a guess but you likely have your laser configured as a “iLaser” device type.
You need this to be set to “GRBL”.
Retest.
If that’s not the issue can you push “Save gcode” and save to a file with a .txt extension and then post the gcode here for review?
That fixed it! Thanks!!
