Error 22 feed rate
so, I traced an image and set the layer to 03 but kept getting this error, I changed the layer to 02 and it works fine, what is it with 03?
ok think I figured it out, seems that layer 03 was saved as a cut layer so I believe the speed I had set was too fast for cutting, had 9000 mm/m for scratch paper, I reset the layer to default and all is fine
