Error:5 Homing cycle is not enabled in your Grbl settings.Ortur
I have the Ortur laser and used my Rotary for cup and now cant get my home to work again. I have went to Machine settings and Homing is green. Where else might it be changed/
What did you change in machine settings to set up your machine?
In the machine settings gui, you can save a file ‘no-rotary’ and ‘rotary’… whatever you wish to call it. This allows you to read the file and restore the configuration. That should have been done before you modified the values.
Don’t know about Ortur, but I usually have hard limits enabled. Some where you followed some instructions on how to setup your rotary, maybe if you back tracked the setup it will help you find the issue.
Have you disabled/enabled the rotary in the Laser tools → Rotary?
I have rotary turned off in the settings for Rotary. I do have both hard limits green in machine settings.
On the first use of the rotary, what steps did you take to make it work?
Did that involve any changes to anything, software wise?
more then I could remember changing. I ended up at Ortur’s Website and used a free GRBL program that let me make the changes. Thanks for eveyones help
