Error:8 La commande Grbl '$° ne peut être utilisée sauf si Grbl est IDLE. Garantit le bon fonctionnement pendant un travail
Hi everyone,
I ve a problem since today. When i turned on my laser it make a « bip »
In thé console an error message appeared « error 8 thé command grbl cannot be used
Other people had this problem ?!
I have found a good resource for Alarms and Error Messages:
It seems that the engraver is active. You may have a project in memory.
Does your engraver have an SD card slot?
Do you usually connect to the engraver by USB or wireless?
You could clear the memory by unplugging power and USB from the engraver and then turning it on again.
This may be a similar problem:
