Error after upgrade to 1.6
Hi all,
I upgraded to LightBurn 1.6 for my Longer B1 30W, when i try to burn an image I’m getting the following errors…
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Stream completed in 0:00
ok
Grbl 1.1 [‘$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
FW:LGT V1.2.3|MB:LS_ESP32
ok
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
I have reset the connection, but I don’t know what the resolution is.
Any help would be appreciated…
