When trying to burn text that is curved upward to match the curve of a circle it burns 1st letter OK but then the laser head moves upward and hits the top of travel and makes grinding sound, so I have to stop the job. It usually will work OK on text curved downward.
I’m using V2.1.02. I finally decided to try it using an older version, V1.7.08, and it ran the job perfectly, no problem burning curved text.
I’d like to test with your file to see if I can get one of my lasers to show the same behavior. If your file is something family-friendly, non-political, not private or under copyright protection, feel free to post it here.
You can send the file to me directly for any reason if you don’t want to share it publicly.
The tech with Sainsmart just sent me a message and asked me to turn off “enable z axis”. I did that and ran the job and it worked perfectly. Looks like that was the problem. Let me know if you think that was the right thing to do.
