Error code 11 on Gluwphy 10watt
I am getting an error code 11 during the cutting. Then when I hit the power button and shut off the alarm I can’t figure out how to restart from the same spot. I have a Gluwphy G1 10 watt. Please help. I am brand new at this and not real tech savey
This error says one of the GCode lines had too much text in it. I seriously doubt Lightburn would cause this. Are you using other software to create your CNC code?
View the NC code in a text editor and see if you can find a line that is seriously long.
How repeatable is this problem? It could be you have a communications (USB) issue.
