Hi,
Every time I try and run Lightburn, I get error 0xc0000102; Lightburn software failed to start.
I’ve tried re-installing the software, it still gives the error. The only thing I can think (from looking at other forum posts with different but similar issues), is that I have recently installed Visual Studio Community 2019, and with it everything .Net related - all the redistributables & frameworks etc.
Windows 10 Pro; Version 20H2.
Lightburn Version 0.9.23
I’ve not seen that before. If I had to guess, I would say that something went wrong during the Visual Studio installation and some of the libraries in use aren’t loading properly. This is referenced online as a “severe windows error or OS corruption”, which doesn’t sound good. Is it only LightBurn that seems to be affected?
It is only Lightburn that appears to be affected… but I have noticed the occasional BSOD (once a week perhaps) on startup recently so perhaps something else is corrupted in the background now.
I will try removing visual studio, and if that fails to fix it, perhaps a format and reinstall is in order…
Just an FYI on this; I uninstalled Visual Studio - it worked. I reinstalled Visual Studio - it stopped working again. As far as I can see; there are no problems or errors with VS’s install.
Anyway - for now, I will live without Visual Studio!
