RicardoHipp
(Ricardo Hipp)
September 6, 2020, 12:22pm
1
Hello
i have the same problem like in this post
Hi,
Im running GRBL 1.1e and Im having this issue:
Starting stream
error:22
On or near line 4:
Stream completed in 0:00
ok
[MSG:Pgm End]
ok
Ive found the error on GitHub: error:22 Feed rate has not yet been set or is undefined.
How can I fix it? Any help appreciated . Thank you in advance
I m running GRBL 1.1e and I
Starting stream
error:22
On or near line 4:
ok
[MSG:Pgm End]
ok
I tried it with an older Version 0.6.04 Beta and it works
.With the 0.9.16 or with 0.9.07 it dont work.
Can you help? is there a solution?
“error:22” : _(“Feed rate has not yet been set or is undefined.”)
Click ‘Save GCode’ and save the code to a text file, then open it in notepad and copy the first ten lines here.
Marty
(Marty Forest)
September 17, 2020, 2:21pm
3
In my case the problem was a .png image was out of the boundaries, but only the empty backgruond.
The preview showed nothing but LightBurn still tried to engrave. The solution was to bring the whole image back to the grid laser boundaries.
There’s a toggle switch in the settings to change this:
system
(system)
Closed
October 17, 2020, 4:17pm
5
