Estoy tratando de grsbar imagenes en escala de grises, pero el.contador termina el tiempo pero sigue grabado ya que no ha terminado la imagen y mitad de proceso de remarca mas cierta area.
Si lo hago con otros parametros es algo similar,
By “timer runs out”, do you mean the USB disconnects and Lightburn stops feeding data to the laser?
Could be the Windows USB Energy Saver kicked in. That disconnects the port.
To prevent Windows from turning off USB devices to save power, disable the “Allow the computer to turn off this device” setting in Device Manager. For a global fix, disable “USB selective suspend” in the Control Panel’s advanced power settings. These actions stop peripherals like mice, keyboards, and external drives from unexpectedly disconnecting.
