come posso visualizzare il tempo trascorso per un progetto finito , lightburne me lo fa vedere per un minuto sotto la barra dei livelli , ma poi scompare e non so se ce una funzione per richiamarlo , considerate che se kacio un progetto a terminare quando ritorno non trovo nessun riferimento al tempo che ce voluto per completare
how can i view the time spent for a finished project, Lightburn shows it to me for a minute under the levels bar, but then disappears and I don’t know if there is a function to recall it, consider that if I tell a project to finish when I return I don’t find any reference to the time it took to complete
There is nothing to recall, but you can get an estimate in the Preview window. It is not exact for several reasons:
- With buffering, your laser will continue to run after the program is completely sent.
- It uses your machine parameters to estimate the time. If the parameters are not accurate in Lightburn, the estimate will not be either.
- If your machine does not accelerate, decelerate, and move as the parameters say it should, the estimate will be off. There is no inertia correction in the system.
I have found the line mode is pretty accurate. The image mode seems to take 2-3 times longer (varies depending on image and mode) than the Preview window. estimate.
