Everything is taller than intended
For some reason everything is cutting taller than the actual dimensions. Like it’s stretching everything taller. For example: 25x25mm circle is coming out 25mm wide - 30mm tall.
Started suddenly after update to 1.6.01
Thanks
1st thing I check is all your setting for Rotary are turned off
BINGO!
I must have clicked on it.
100% operator error.
Thanks for the help
