Any one had trouble with Import and export since the 1.5 upgrade as mine no longer works just can’t open any of my saved files worked fine before upgrade
Import and export are not supposed means to save files and reopen them, they are more to communicate with other programs, using different file formats.
So, what format do you export to and try to import back?
Can you open an exported .svg in your internet browser?
I am trying to send already lightburn saved files from main frame to laptop via SD card worked fine before upgrade won’t work now though
Unless I misunderstand, copying files between folders/drives/computers should not require Lightburn at all. Simply drag and drop from within Windows.
