I just did the 0.9.23 update now when I burn a project that I have burned multiple times the carriage is moving past where it used to. I went back and installed the previous version and it is still doing it. It is adding a lot of time to the burn that is unnecessary. How do I fix this?
Make sure have ‘fill shapes individually’ selected under the cut settings editor, that hopefully will reduce burn time
YES!! That was it. I assume something in the update changed that setting. Knocked 12 min off the burn and unnecessary movement on the machine. Thanks so much!!
