EzCad 2 and EzCad 3 Z-Axis and Rotary Issue
I made some tests with LightBurn 2.1.00 RC 11 but got some issues:
I am using your driver V2.0.0.0 27.02.2026
EzCad 3
I have problems to run rotary axis on EzCad3 DLC2-M4-2D controller.
Only z-axis works, rotary doesn´t work. EzCad 3 software can control both on same machine.
Lightburn shows two Axis 0, but both doesn´t work. Z-Axis as Axis 2 works
EzCad 2
I use LMCV4-FIBRE boards with 2 axis parallel support.
EzCad 2 software can control both axis (z-axis and rotary) on this machine.
Lightburn shows motor 1 and motor 2 but only rotary axis moves an both motor 1 and motor 2
Do you have any idea what can i do to have it running with your software?
EzCad 3
EzCad 2
Do you have any idea what can i do to have it run with your software?
EzCad 3 works now!
It is really important to import the motors.ini fromthe EzCad3 folder.
Manually i had no chance to configure both axis together.
