with a ruida controller i had an issue yesterday where lightburn crashed of sorts and started as though it was a brand new install…first time ive seen it do this
since then i keep getting a transfer failed when trying to upload a file to the laser and if i just hit start it starts the job, fails to send all the file across so the job stops part way in
i copied the file to a USB stick and ran from there which worked fine but im not sure why i suddenly have this issue
any ideas (lightburn .0.9.09 then upgraded to 10 and have the same issue over ethernet
What does ‘crashed of sorts’ mean? Did it bring up a window that tells you to take a screenshot and send it to lb email? You have the same issue whether you use USB or Ethernet?
by crashed of sorts i mean i started lightburn as per normal but it opened up as though it was a first time install…had lost all settings including IP address and scanning offset settings
since this moment i am having a hell of a time sending files
