Hello everyone! I am very happy to know that this forum exists.
I have been learning to use the software for a little over a month and in the last few days I have noticed how when I send an engraving and cutting job to the machine, for some strange reason, the cut moves.
Let me explain: First, it makes the engraving correctly and then when making the cut, it seems as if the machine moves a few millimeters, causing a movement effect that makes the work useless.
I have a 50w Chinese machine that was sold to me as a premium and it works quite well, it is perfectly aligned and clean and it is no more than 2 months old.
I have posted the query in this category because they tell me that hardware is not the problem.
Improperly configured motor / step controller settings
The last one is probably the least likely, but I’ve seen it a few times. If you do a simple square, set to Fill+Line, if the fill is slanted and the lines are not, it’s the last item on that list, otherwise it’s likely one of the first 3.
The physical build of the machine is likely not, but the configuration they sent you might be. I purchased a 100w machine from China a couple of years ago, and the acceleration settings were really aggressive and caused work to slip until I backed them down a little.
You haven’t shared details about what settings you used with the above designs, so it’s hard to give specific suggestions.
Thank you, I will send more information and parameters shortly.
Before leaving work I have done some tests and realized that the problem may be the recording. It appears slanted, as if it were a recording in italics. Tomorrow I will send photos and parameters.
Excuse me, I thought that marking Oz’s answer as resolved understood that this is the solution
Solution: for Laser 50w Ruida 644xs
In the Machine settings for the X and Y axis will be a checkbox called “PWM Rising Edge Valid” - change that from whatever it is now, and that should do it.
