I’m having trouble engraving 5mm slate (20x30cm) using my Sculpfun S30 Pro and LightBurn. Following standard speed and power recommendations results in engravings that are far too faint and washed out. Currently, I have to run 2 or 3 passes to get decent contrast.
What speed, power, and interval settings do you recommend to get a crisp, high-contrast engraving on slate in a single pass with a 10W diode laser? Any recommended image modes or prep tips (like oil/clear coat) would also be appreciated.
Welcome to the Lightburn Forum. This is where all questions get researched and hopefully answered.
Every situation is different. I have the same laser, but your settings might be different than mine. Is our slate from the same manufactureing batch?
Speed and power recommendations. That means there is no"standard", and the numbers are just a starting point to get you close. Nothing wrong with your machine, software, or procedure. You left out the most important step: Final Tuning for Optimum Results.
Without a picture of your results and knowing your Cuts Editor settings, is is difficult to know if doing it in a single pass or multiple passes is the right choice.
Your original image is pretty important because it most likely has a lot of tones you can’t get out of slate. You’ll need to compensate for not having true black or true white and your shades in-between have to be teased out of four-five tones slate will give you.
Start with a Dither pattern as Greyscale can look washed out until you get to know it. For example, if you have a strip of black to grey with eight shades in between, you’ll probably get four usable/distinct colours…that makes images look washed out…No punch!
Try around 2000mm/m and various power from 14.5% up to 40%..watch the difference.
If your laser dot is approximately 0.1 you’ll be looking for best detail at 254dpi…but drop it to 230dpi and note what you get especially at higher power to punch out those bright tones…but it’s not all about power! Its a lot easier to see individual contrasts in larger images than smaller ones and each image has its own recipe..and each slate can be a different type.
I did this photo of a neighbour a couple of hours ago.
Your using a newer version of lightburn so the screen layout is a bit different to mine and the image is also out of focus on my phone screen so I cant read the numbers, and it’s in German so I can’t judge what is what.
The photo looks good in greyscale and it looks like it was taken on a sunny day so there are some shadows to deal with.
What size do you want the image to be on the slate (X x Y) in ‘mm’ dimensions and What size laser dot are you using.
Have you practiced on any scrap material and could you show us what results you have achieved so far. The Preview screenshot is OK but can you show the ‘Image adjust’ window as well as ‘Cut settings’ each as a full screenshot.
Thanks
Ps. Could you post the original image so I can run it and show you the settings and outcome.
That is a very good outcome, well done and your text engraving is wonderfully crisp. As you can see the only issue is with the shadow on the faces looks like the only issue.
At the moment I can suggest that increasing the ‘Minimum Power’ by very small amounts until this shadow lifts to a more natural appearance, or…
Reduce the Gamma/Contrast in ‘Image Adjust’ very gently or..
Use a ‘Local Contrast’ adjustment on those specific areas in an image processing software such as Gimp.
I also just noticed that there is some high-contrast in areas for example just where the neck and the T-shirt meet. You may have just a little more sharpness than you actually need, so with a very slight reduction in Sharpness, Contrast, and Gamma might spread the overall reduction effect across these three, so no individual adjustment has do do all the work.
Also, the slight increase in Minimum Power that I mentioned, would only apply if you are using Greyscale image mode.
I suspect you may be as good with PS as LB so this should work out very well…Kein problem.
If that M-D-M Image is the original, I see a very faithful reproduction. I think if you push the brightness in some areas, you will lose detail on others.
The top left is the original. Top right is slight change on the tone-curve. Bottom left is Tone curve + LB image adjust. Bottom right is same with further image adjust.
I tried local fuzzy-select on the shadow but it resulted in banding…so I selected most of the head and used Curve-tool to alter…And as you say, the lightening was added throughout the selection.
I indexed the image and tried to locate the specific shadow tone but failed so I consulted with ai and got instruction on how to use the pointer on the image in combination with the entire image curve to locate the x/y area and tone-value specifcly…then adjust the curve right at that spot.
I hope you had some success with PS to adjust the shadow’s. I did not have much time yoday and it proved difficult working on the whole image and the shadow’s on three faces rather than just one.
