Falcon 2 22W engraving pass trough (laser is ON all time, on moving too)
Can you help me where the problem could be?
My new Falcon 2 22W also engraves auxiliary lines through the material.
Where can be the problem? I tried it on Lightburn and LaserGRBL too, but but he does it all the time.
Laser dont turn off and on, is all time on, if is moving too, all time…
Hi @Chatko
It is likely your controller is not in “laser mode”.
In your console window type $32=1 and press enter.
We also have a guide for this issue in our documentation:
Hi, i have $32=1, i googled it and this settings is ok. That is why I wrote here because I dont know what else could be causing it.
Does the power change or is it running at 100% at all times? If it seems stuck at full power the laser could be wired incorrectly.
Yes, power is change - is different. I can engraving and cutting with different power and speed, but with traveling line on :confused:
Can you give us a screen capture of the Machine Settings window to confirm the value?
