Falcon2.lbdev File
I’m getting a message that says the laser is busy or on pause. It is neither. Creality tells me I have to install this file into LightBurn. I have looked here, on Youtube, can’t find anything in ENGLISH to tell me how to do it.
Is this the right approach? If so how do I do it?
You can drag your lbdev file directly into the LightBurn workspace. Simply drag and drop anywhere into the active workspace to install your machine profile.
That did something. NOw I’m going to go try it. THANK YOU!
OK I got it. So stpuid. I switched the COM PORT from 3 to 6 and it worked. Now I have to do some material tests. See how it works. But I have communications now.
