Fallo a la hora de grabar
Hola buenas, puede ayudarme alguien a solucinar el porque al grabar me da fallo al ratito de estar grabando,en la consola me pone esto ALF:121. ALH:AlgoLaser MK2 V4.0. ALM:GENERAL. Se para y no me deja continuar desde donde se paró
Hi there, can someone help me figure out why my recording fails after a short while? The console shows this: ALF:121. ALH:AlgoLaser MK2 V4.0. ALM:GENERAL. It stops, and I can’t resume from where it left off.
Many things can caise it to stop: Overheating, USB communications failure, out of bounds error, and more.
ALF:121 = You need to contact the manufacturer to learn what this means. It may be che reason for the stopping, or maybe not.
can’t resume from where it left off: The controller buffers the data stream. There is no way of knowing at what point in the program it actually stopped.
Hola buenas, puede ayudarme alguien a solucinar el porque al grabar me da fallo al ratito de estar grabando,en la consola me pone esto ALF:121. ALH:AlgoLaser MK2 V4.0. ALM:GENERAL GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]. Se para y no me deja continuar desde donde se paró
Portable Windows or Portable IOS?
Portátil Windows
Have you turned off the USB energy saver feature in Windows?
Are you using a quality shielded USB cable which has a ferrite (noise supressor) on it?
Is your USB cable length less than 10 feet (3 meters)?
Can you copy the actual Console message and paste it in your Reply?
