Fast home sted kan i hjælpe mig (Fixed home - please help)
hvordan kan jeg få min laset til at hå en fast home sted.
for når jeg trykke på home kommer der en fejl 5 frem
how can i get my laser to go to a fixed home place.
because when I press home, an error 5 appears
Error 5 means that your GRBL controller does not having the homing cycle enabled. For this you need homing switches installed in the machine, and have to change the configuration to enable homing. Read this: Grbl v1.1 Configuration · gnea/grbl Wiki · GitHub
Fejl 5 betyder, at din GRBL-controller ikke har homing-cyklus aktiveret. Til dette skal du have homing-switche installeret i maskinen og skal ændre konfigurationen for at muliggøre homing. Læs dette: Grbl v1.1 Configuration · gnea/grbl Wiki · GitHub
