I have spoken to Oz about this before but i have seen it again with V09.02
so in LB if i cut a square for example all is ok…but if i move the laser head away from the set origin …and then press go to repeat the same program …the laser beam will turn on and cut all the way from the current position to where the origin is set
in RDworks…doing the same - the head rapidy moves to the origin and then the beam turns on which is how it should be…
you can see the probem on the display unit where with LB the path to the orgin shows as a cut line on the display …
has anyone else seen this issue and Oz are you any closer to fixing it
if you would like to see a video of what i am talking about
this is Lightburn
this is RDworks
in both instances i cut a shape then simply moved the head to another position then hit the start button to run the same program again…
